tubenewb
- Aug 10, 2010
- 86
I am replacing some 1/2" Plywood pieces in my boat..I plan on using poly,1.5 csm and 6oz cloth ..
Is there a certain pattern to follow ? Should I come around and over lap with the csm in one direction, then come around and overlap with the cloth in the other direction?
My my concern is how do you glass all the edges?
I guess you could slit the corners and fold over but I was guessing there needs to be overlap .
I am definately using the csm/6oz on the top side , doe anyone think I should continue with the 6oz on bottom side as well?
Thanks in advance
Thanks in advance
