Best tach on a budget for diagnostics/tuning?
Eshaw150
Re: Best tach on a budget for diagnostics/tuning?
you are going to get mixed respones on this
i like to use a faria tack its a plug in and american made
D
DJ
Guest
Plenty avialable here on iboats. Go to the Marine Store (upper left corner).
I've used just about every brand. Never had any trouble with any of them.
Mas
I guess I should be a little more specific. I'm looking for a hand-held or maybe something like a tiny-tach...nothing like a dash-mount, but rather a laser reflective or inductive hand-held. I did not see anything in the marine store that was a "hand held?" Maybe I overlooked one?
MAS
D
DJ
Guest
You won't find one here. You are looking for a "tool".
There are plenty of choices out there. The trick is finding one for a two stroke and two or three cylinder engines.
You can use a four stroke tach, just 1/2 the reading.
I've used my four stroke handheld tach. (inductive type) on outboards. But, you have to "interpret" the readings.
tashasdaddy
for diagnosis only and proper set up, you can use a timing light with the tach function. i use a tiny tach, get my motor properly set up, then put it back on the shelf, until i want to check again.
personally i hate instruments on a boat, just something to break or something to make you worry. on and i/o they are a necessity.
Willyclay
Take a look at:
Reed AT-6 Photo Non-Contact Laser Tachometer, MSRP=$89.00USD
EZ-Tach Digital Clamp-On Tachometer, Model 325, MSRP+$59.00USD
Post what you decide on!
ezeke
Rocky_Road
I just found a Matco Digital Inductive Tach/Timing light on eBay for $80., plus shipping. It arrived, and is in perfect condition.
I then placed my old Craftsman Inductive timing light up for auction...and got $41, plus shipping.
All said...I replaced my 20 year old Sears light, for a Matco digital tach/light...for about $39.
Could work for you!
Mas
Wow, thanks guys. I'll look over your recommendations and let you know. I am looking for digital...but I am on a budget. I like the idea of a tiny-tach and not permanently installing it. I do not like the idea, however, of the battery only lasting 5 years...which then cannot be replaced...then have to throw it away! :-(
Anyways, I'll check 'em out,
MAS
