Re: Best rod holders
Here's what i use for rod holders. Plastic pipe, cut into 4,5 inch wide pieces, cut a slot in the piece for the rod and reel to go in, cut a slot for the rod, drill a hole with a hole saw for the rod handle, cut a slot for a carriage bolt to raise the angle of the rod up or down, and mount to rail. These work great. I have a pontoon boat, so i just drill a hole in the top rail, the same size as the carriage bolt. A little work, but not much, maybe 15, 20 minuets per holder.
These could be perminately mounted to a fiberglass rail, using a threaded anchor in the rail. Might not look very good, but would work.
Just sharing, thanks
