Re: Best Recommended Alpha 1 Lower Unit Oil
Going to change the lower unit oil on the 1989 Alpha 1 in a couple of days. I know there is the Mercruiser brand, but are their other, less expensive and more available brands that some of you use and recommend? Thanks, Rick
Believe me, you'll get "recommendations" from people here and on other boards that will include EVERY BRAND in radioland!
Understand that there IS NO NMMA, SAE, or API "Marine" gear oil "specification".
Mercury Marine, AM$OIL, Volvo Penta, and OMC(BRP) claim their "branded" oil is "formulated" to still meet "requirements" with water contamination" and AM$OIL even has posted some "test results" claiming up to 10% contamination performance etc.
If you do a search for gear lubricant "D3233B water contamination" you'll find that just about all the gear lubricant manufacturers test for performance with water contamination. (the possible reason NMMA hasn't bothered to come up with a specific marine spec for gear oil)
A LOT of people including a rather experienced tech that resides on this board, use Mobil 1 syn 75W-90 oil.
Since synthetic oil will not be thicker and MORE viscous when cold, you might notice a little easier shifting when the drive is cold. and when you change it, it will drain faster.
You can buy the stuff above just about anywhere......including "Wallymart"
ymmv.
Regards,
Rick
