Best Prop for 75 HP 4 Stroke Mercury
vtcart
I have a 2001 75 HP Mercury 4 Stroke on a tracker nitro 640, what prop would you recommend for this engine? It has a 18P Mercury vengence on it but looking to replace due to damage.
Did it run with the current prop in the max recommended RPM range before it was damaged? If so, the pitch is likely OK. If the RPMs were lower than the max recommended with a typical load, you need less pitch. If the max RPMs were higher than the recommended range they you need more pitch. 2" less or more pitch would normally raise or drop the max RPM by about 400RPMs.
The boat looks to be a bass boat-style. For best performance on that high speed hull, you will want a 3 blade prop in aluminum or SS. Turning Point Hustler in aluminum is fairly high performance, vented for a bit better acceleration and fairly inexpensive. In SS, maybe a 3 blade Apollo?
airshot
Best prop can't be answered without a host of information to go along with that question.......many, many factors go into making that determination..
Texasmark
......and the Turning Point Hustler. is probably cupped, like most SS props. I have a half dozen TPs sitting on the shelf...... unlike most, if not all other brands of aluminum props. "If it ain't broke don't fix it".....as the saying goes, if you liked the 18P Vengeance, why not repeat that purchase. "Any" time you change anything about the prop you are running you are setting yourself up for the unknown. Why set yourself up for potential problems and $$$$$$ blowing in the wind? I have puked a lot of money on playing with props to achieve a certain goal over the years. BTDT
