Re: best product for filling holes in aluminum
thanks guys-------- lakelover- did you leave those press plates on the back of the holes or remove them. ( wouldn't they be unsightly having them all over the place? I have about 28 holes to fill. The rivet idea would be good if i only had a few holes but i have many and dont want anything showing. I want to have a flat original surface when done.
You've got a point there. I only used that method on the gunwales and front deck where the backside is not visible. I removed my side rubrails and brackets, and filled those holes with solid head pop rivets dipped in 5200. Without counting, I'd say there are 6 to 8 on each side. I painted over the pop rivets and on a riveted boat, you hardly notice them. Don't know how you would achieve your goal of nothing showing, maybe somebody else has an idea.
Edit: just saw djpeters' TIG welding method. If you've got the shop and $$$, go for that.
