Expidia
- Aug 26, 2006
- 2,368
I took my prop off my 40 hp outboard when I stored the boat covered next to my garage and coated the shaft with some grease. The prop is in my basement awaiting a paint touch up.
I greased it up but as I was walking by it after the snow melted last weekend and I thought I saw rust on the prop shaft. it's probably grease but is this a bad way to store it?
Last year the prop was on the shaft over the winter.
Should I just put the prop back on so as to protect the shaft from rusting or does someone have some tips on how to store the outboard over the winter without the prop on it?
It's in the upright position, but I figured if I put the lower unit in a plastic bag it might be worse as it will hold moisture inside the bag.
P.S. I didn't put this post in the prop thread because it's more of a winterizing question and not about prop performance!
Thx
Thx
