QC
- Mar 22, 2005
- 22,783
I am sanding down mostly epoxy layers (some wood) and then cleaning those before applying either more epoxy, epoxy filler or eventually paint. What are the best/cheapest solvents or cleaners to use between layers, application etc.? I have been using mostly vinegar so far, but I have only been dealing with the bilge. Got that from work I had done on an aluminum boat and I have no idea if I am making things worse or better. I Just tried some turpentine for the heck of it and that seemed to work real well. I also have a gallon of Xylene that I am using for thinning single part epoxy paints. I understand that I can simply use whatever the manufacturers recommend with a cool in-house brand name. My suspicions are that these are generally off the shelf type compounds just repackaged by them.
Thoughts? Suggestions? Scoldings?
