Best 6 cylinder tow vehicle??
jlinder
Re: Best 6 cylinder tow vehicle??
gunshot grouper,<br /><br />I checked on the ratings for the 2004 Grand Cherokee (you did not give a year), with the 4L 6cyl. ( http://www.trailerlife.com/downloads/04towingguide.pdf )<br /><br />They rate it for 5,000 pounds with the factory towing package, and only 2,000 pounds without. Have you done any aftermarket mods? (transmission cooler, etc)<br /><br />It might pull ok, but you are over the factory ratings. I would be concerned with wear the and tear you are putting on the vehicle. I would be uncomfortable towing what you have with that vehicle.
broark01
Is there a naturally aspirated, mass produced, gasoline powered 6 cylinder with more HP than the GM 4.2L I6 found in their mid size SUVs? I have towed with both the Trailblazer and the Envoy and both do a great job if you disregard the RPM. The torque curve is better than most V8s and the engine is inherently smooth. I have towed in the max range 6-7k lbs and am pretty satisfied with the performance.<br /><br />The engine has won some awards over the last several years:<br /> Great Vehicles Need Great Engines <br /><br />A quote from TB Mag:<br />
...Trailer Boats previously tested the short (113-inch) wheelbase 2002 Chevrolet TrailBlazer (Playing It Straight, June 2001) and the 2002 GMC Envoy (2002 Tow Vehicle of the Year, February 2002), both powered by the Vortec 4200 (4.2L) I-6 engine. Weve gained respect for this fast-revving, high-torque, straight-six, which has been upgraded for 2003. In fact, the 2002 GMC Envoy came close to being crowned 2002 Tow Vehicle of the Year...
SteveRay
Originally posted by trollhole:<br /> <br />But any v-6 I would choose the new TDI Diesel V-6 VW Touareg comming out next year. Towing capacity is 7600lbs.
The toureg is actually a V10 with 310hp and ~500 lb ft of tourque. It goes for about 55K according to Go Boating's recent article. Im a vw fanatic and that is one sweet SUV none the less
BigPoppaG
I use my 98 JEEP Wrangler. Tows like a champ.
cuzner
Trail blazer is the way to go. I have a v 8 durango that does a nice job, used a freinds trailblazer last summer for a week, and could'nt believe how well the 6 towed my boat ( more power than the durango, ride wasn't as nice)<br /><br /> Jim
