Bent shaft
Big D
After hitting a rock with my 3.0 alpha one sterndrive I have .060" runout at nut end of prop shaft... can I live with this...I am thinking of using a comprop because its light weight<br /><br />------------------
12Footer
Re: Bent shaft
You could get some miles out of it by babying it. There may be a buncha vibration,and the seals will therefore fail much faster. The light prop will help.<br />The best scale to judge on,would be lube condition after each trip. Buy a pack of pipecleaners from the drug store,a 5pack of vent screw gaskets,and check it thru the "vent" screw hole (like a dipstick on oil). If it's milky, like a peanutbutter milkshake left in the sun, the seal has failed,and is due to be torn down.<br />You will quickly get an idea it's ok if, after you ran it a few times,and still have no water in the lower end, that it's probably<br />best to "run with it". Good luck with it,and tite lines.<br /><br />------------------<br />the Early bird get's the worm...So, he don't have to stop for bait.
ODDD1
Re: Bent shaft
Big D, mercs spec on runout is .005"....060" is way more than you should ignore....
Big D
Re: Bent shaft
.060 was a guess, I just meausered it and it was .029". still way out but better.
Big D
Re: Bent shaft
