CalicoKid
- May 27, 2002
- 1,599
Hi, I'm in need of opinions on replacing a bent prop shaft on a '96 Johnson 115hp v-4. What typically gets replaced other than the shaft? What kind of parts and labor can I expect this to cost typically? The prop found a rock which resulted in the bent shaft, it is visibly bent when spinning the prop by hand. This is not my motor but could be soon. The damage was done about a week ago so not much running after the impact occurred. Any informed opinions much appreciated, thanks!
