BENNET TRIM TABS
toddmangin
I have a strange situation going on with my Bayliner. When I look off the swim platform before I board the boat I notice no oil sheen in the water. The second I step on the platform I can see a sheen come up. Obviously the drive is submerged and so are the lower part of the trim tabs but the top part of the tabs don’t go under water until I step on the platform.
Seems like maybe a leak in the top part of the tabs but I see no oil at all.
It’s very confusing.
Ayuh,..... Welcome Aboard,..... Is the oil low in the tab pump, or the drive,..??
The tops of the tab struts are solid, except for the fitting inside the hull,....
dingbat
Could be a leaking trim pump hose (Stainless) or fitting.
If that isn't the case, more than likely the o-rings in the piston heads of the trim tab actuator(s) have gone bad.
