Bench test stator and rectifier------ VIDEO INCLUDED---- NEED YOUR HELP!
mgusha16
please review this Youtube clip. we need to know if these are proper reading for the the stator and rectifier. and if they are not proper readings please let us know so we can replace them. the parts are off of a 1988 150hp STL model Evinrude. please comment if you need addition info. otherwise please click on link and watch the video to help us out! thank you so much!
Bench Test 35amp stator and rectifier - YouTube
Re: Bench test stator and rectifier------ VIDEO INCLUDED---- NEED YOUR HELP!
Why are you doing the testing.----------The stator does 2 things.-----It provides voltage to the CD powerpack for ignition.---------A totally seperate circuit is used for charging the battery.---------Are you testing as per a factory manual ?
tblshur
mgusha16, cdi electronics web sight is very helpfull in checking stators and rectifiers good luck.:)
clanton
Can`t see which wires you are connecting to, are the numbers on the meter. Important you connect meter to correct wires for testing.
I can get you the OEM specs if needed.
