Bellows
hunterny
I'm installing all new boots on my Alpha drive.I installed and glued the driveshaft
bellows on the bell housing but I see its off center just a 1/8 inch should I
take it back off and recenter it?or will it be okay
thanks Lee
EddiePetty
Re: Bellows
...a picture would be really helpful!!!!
As long as the grounding tabs are in position, the bellows is completely over the raised lip of the nipple and the bellows is indeed securely glued, very little chance of a leak. Ensure that the clamp has full contact with the 'neck' of the bellows.
