SeattleBob
Thread starter- Joined
- Jul 5, 2011
- 15
Hi All,
I decided to change out my existing trailer lights with LED's to get better lighting and to try to fix a fading blinking problem. The old lights worked fine as running lights and the right blinker worked okay but the left blinker was dim. I changed out the lights with the new LED taillights and now no lights work anywhere on the trailer (no side lights closer to the middle of the trailer, no tail lights, no blinkers). I am using the same wiring in the back as was their previous but am getting nothing. I checked the 4 pin connector with a test light on my tow vehicle and am getting juice through there. I tried the same test light on the wires on both back lights on the trailer and am not getting any juice through them. It is driving me crazy. I am towing it with a 2008 Honda Pilot. Could it be a bad ground connection? A bad fuse somewhere? Something else?
Any help or thoughts would be much appreciated as I am going a little nuts with this thing!
Thank you in advance.
