Bob La Londe
- Jan 26, 2004
- 196
I was using some epoxy resin today for a nonstandard application and I was thinking it might flow out a little smoother if it was thinned a bit. This was one of the best articles I found on the subject.
Before thinning epoxy read this article.
http://www.seqair.com/skunkworks/Glues/WestSystem/Thinning/Thinning.html
It was the very first search result I saw. Basically says that conventional thinning is a bad idea. Just 5% chemical thinner can reduce strength by 35%. It does go onto to mention bringing up the temperature of your base material as a good alternative. Where I live that means set it outside for a minute in the summer time.
