beep beep beep. oil alarm issue
robaloroger
1999 200hp carbed. when I turn the key I get 3 beeps. I cracked my oil reservoir cap and replaced with a used one and now get beeps at the ignition turn and while running. I took the cap off and pushed the float up to indicate full tank and it still beeped. Dropped float down to indicate empty tank and got the same beep. I disconected the ground and lead wire and still the same. Should the beep stop when I disconnect the cap warning sensor?
Robot1947
Re: beep beep beep. oil alarm issue
The float switch completes a circuit to ground so the oil warning horn should not sound when the float switch is disconnected.
There may be other issues with the oil warning system.
See the Applications Guide on www.marinesolutionswi.com web site for tips on how to check out the oil warning system.
j_martin
yes.
