voodoochikin
- May 20, 2012
- 126
quick background. 1990 bayliner capri, 90hp force outboard 2stroke. ran fine all last year, I winterized it (fogging oil in cylinders, stabil in the gas) but i didnt run the stabil gas into the engine. (first time winterizing a boat-read as naive)..
so I took the boat to the water yesterday. I didnt add new gas cause it had a 1/4 tank yet. Get boat in water and crank and crank. It finally starts but revs to full throttle while in neutral!!! everytime I start it, it just winds up as high as it can go until I shut the key off. I have no clue why this is happening. Nothing on the linkages should have changed, I didnt touch anything on the engine. Everything appears to be moving like it should.
I couldnt find ANYTHING on google about anyone having this issue. My thoughts were that that gas might have issues from sitting for 4months, even with the stabil. The carbs might be plugged from having untreated gas sitting in them? The engine is running lean??
This is really bothering me as nothing was messed with or changed from when I parked it. PLEASE HELP..
