I have an 07 Tracker 1436 jon boat that has 2 cracked welds on the transom. If you look at the pic a cracked weld is circled in red and from what I can see, the corner brace is missing a weld which I marked in yellow,,, the other side is the same way. It's going in under warranty to have it welded.
When I get it back from being welded I want to make the transom stronger by replacing the current exterior and interior transom plywood and adding in a knee brace.
Any suggestions on how big I should make the interior and exterior plywood pieces and what is going to be the best way to add in a knee brace?
I'm not sure if the welds cracked because the corner brace is missing a weld or if there is too just much flex in the transom, it's always been really wobbly and flexible and I want to make solid so it does not crack the welds again.
