Re: Beating out the cup
"Prop end bias"? Say what? Is that cupping, or is that when the pitch seems to flatten out towards the end of the blades?
No up and down steering limits, I do have a down, which I can put in place. It's a stop on the motor's mount. But I've found letting it hit the edge of the boat is fine too.
And no rotational steering limits. The motor can go all the way around 360˚but of course it can't reach the water all the way around. I could probably steer 270˚, so since my motor doesn't have reverse, it would be like it is if the motor was turned way far around so the prop was up along side the boat.
I was worried about my motor tipping the boat over, so I (being over 200lbs) got up on the transom of the empty boat and rocked and rolled as hard as I could and it felt good. Then once I had the motor on the boat I rolled it as far as I could and let it go - a simple test of the center of gravity - to see if the boat wanted to right itself immediately or if it had any indecision about the topic. It righted itself immediately. Since it is a canoe it can't roll over too far or the side starts drinking the river and it goes to the bottom, fast.
Greg
I think I read about the 2 different pitches on the Turning Point prop site.
Do you have it balanced with a slight prop end bias and do you have stops
to limit up and down and steering limits?
I saw a post about motorized regular canoes flipping over if the motor was turned too far.
I don't know if it applies to square stern and long tail motors.
Greg
