Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
I have to put new front wheel axles on my tractor. The tractor uses a sleeve style bushing in the front wheels. I hate bushings on front wheels, especially on a tractor this heavy because they cause axle wear, even when kept greased.
When I noticed the sleeve bearing was wearing away the axle, I replaced the sleeve bearings with a pair of these common light equipment ball bearings (3/4" x 1-3/8") and kept them greased well. But alas after a few years, they had catastrophic failure. Having the axle worn flat on the bottom probably aggravated the situation. Cost = less than $2.00 each.
Now doing a little research I find these "Heavy Duty" wheel bearings:
The description is:
Item# ST-215-267
HEAVY-DUTY WHEEL BEARING - 3/4"ID X 1 3/8" OD
REPLACES AFTERMARKET PART(S): EDGEWATER 089210 GREEN LINE 16222 MOW MORE IB-34 ROTARY 7869
SPECS: ID: 3/4" OD: 1 3/8" Height: 1 5/32" Universal
The big difference (besides being wider and Heavy Duty) is it looks like this bearing has no inner race and rides directly on the axle. Cost = $5.00 each.
Think I can use these in place of the thinner cheaper ones at the top if I also replace the axles at the same time?
The description is:
Item# ST-215-267
