Bearing made of sugar.
rusty&maxx
I was getting ready to launch yesterday. When I saw a very precarious sight. The launching trailer was barely in the water. The waterline was just underneath the bearings/axles. So the trailer was barely in the water. And the boat that was launching? Well, the owner was in the boat power backing it off, while his bud's pushed him off. It scared the crap out of me when the the stern dropped off and the boat just dropped into the water. Lucky the guy didn't totally demolish his boat. He caught a glance at the 8 people staring at him and said, "I don't wanna get the bearings rusted and messed up. it'll be a pain if they break on the road."
Doesn't matter if he has a working trailer, especially if he doesn't have a working boat, eh?
Re: Bearing made of sugar.
Sure would have loved to see how he planned on getting the boat back on the trailer at the end of the day ! ! ! !
jennis9
The ramp... ahh the craziness that happens there. Saw a similar thing happen at our ramp this weekend for the first time. Powering off the trailer then not tying up - cutting people off and just motoring out like they were the only boat at the ramp. One continuous rude action.
reelfishin
That's not all that uncommon a sight to see, I can't count how many times I've watched such an unloading here. The lucky ones get away without any damage, but I've seen many cracked hulls, gouged keels, and bent props.
I watched one guy a few weeks ago loading that way, he had the trailer backed in only to the waters edge, the boat 'beached' on the ramp and a super sized power winch. He hooked up the boat, laid on the power till the boat started to climb on the trailer. I was waiting for the cable to snap and rip his head off. I was amazed at how strong that cable and bow eye were. He nearly had the trailer frame bowed by the time the boat finally jumped up onto the first roller. I can't imagine what the lower side of his hull and lower unit look like either.
dlngr
I pulled my hubs off this spring.Glad I did. Had to replace brngs on one side.
I'm sure the bearings were made of some kinda metal-not sugar!!!;)
Knot Waiting
Somtimes I think an IQ test should be required at the time of purchace. I would really have liked to see the loading technique he was planning on using.
My ex kept our (well now his) boat at the marina so we didn't have to use a ramp. Not sure if he even knew how to pull a trailer or back one in. I don't either! Someday I need to learn if I busy a boat which I'd like to before too long. :redface:
reelfishin
The IQ test may not be a bad idea, not just for boats either. That same type of boater is the guy that stops a the gas station before the ramp and pumps 20 gallons of gas into a rod holder or the guy that backs his boat prop first into the dock. It reminds me of a customer that bought a new $40,000 Town Car then came back the next day with brake, power steering and windshield washer problems. He said he wasn't sure which place to add which fluid, so he added a little of each everywhere. When I asked what made him think that a 4 hour old car needed fluids added he said that they always take shortcuts when they build new cars and never fill anything all the way up. (No mind to the full marks, color coded caps, or the fact that it was still under warranty either). The worst part is that the dealer warranted the repairs. Who's dumber in that case?
I watched one guy just this weekend load a boat with an I/O, he was already off the ramp and tying it down and it was still running with the prop spinning. All the while his wife and kids are still in the boat playing with the tilt and trim and gunning the throttle. Those I/O's sure make a racket when tilted beyond the run point while still running. He was screaming leave it alone, she was gunning and revving the motor and the kids were running wild all about the boat screaming and hollering.
I hollered over to him that he should shut if off before he burns it up or even worse walks into the prop and got the reply that he was trying to pump all the saltwater out. I watched it run for at least 15 minutes or so, it was still sitting there running when I left and he had pulled off the ramp as I was just pulling on my trailer. I suppose one way of preventing saltwater damage is to just blow it sky high the first time out and not worry about getting it wet again. It looked like a brand new boat, but I'm sure the New had worn off pretty quick after that ordeal. He was also tossing ropes over the boat to tie it down, I guess he had no clue how to use the retractable transom straps mounted to the trailer, or didn't want to get too close to the spinning prop to figure them out.
I usually try to avoid the public ramps like that one but its the only one with good water at low tide. I don't think I've ever not seen something dangerous or stupid at that ramp. It's usually a good one too for boats dropped on the concrete ramp or trailers dropped off the end of the ramp at low tide too. I have to admit, some people can be down right entertaining if you can stay at a safe distance.
Sooner or later I'm sure the process of natural selection will catch up with some people. In most cases, we can only hope they don't take anyone else out with them.
reelfishin
At least I know not to run the motor out of the water! Who wouldn't know that!:cool:
You would be amazed at how many people that will run a boat out of the water or without a tank or hose. I see it all the time, usually long after the damage is done. The lucky ones only need an impeller and not a complete overhaul.
j_martin
The dude with the IO probably read the book. It says "Flush for 15 minutes after salt water use." He just doesn't know that you flush it with water, not air.
Look at the bright side. In short order there's one less dangerous boater to contend with.
John
CATransplant
John
I'm surprised he didn't get in the boat and flush the head for 15 minutes. :eek:
skargo
Banned
Tammy, would you happen to have a larger pic from your sig? I'm trying to determine what kind of fish you have caught there, yeah, that's the ticket. :D
Tacklewasher
Go looking at used boats some day. Set up 10 to look at. Ask all 10 of them to fire the motor up.
I bet 5 of the 10 don't use muffs/tank of water.
