Bearing help
rsthomas34
I have tried searching this site as well as the internet with little help.
I am rebuilding a 1984 15hp Gamefisher, made by eska, MODEL 217-586352.
I need to replace these bearings-
Main drive gear needle bearing Torrington Part Number y-166 sears # 26296
Main gear inner needle bearing sears # 26312
Drive shaft ball bearing Peer # 7201 sears # 26290
Any help with cross referencing these numbers would be a great help. I know that boatsportandtackle has most of these bearings was just looking for help to possibly find a match to source them locally. Thanks
F_R
Honorary Supreme Mariner
The only number there that I recognize is the 7201. That should be a common standard ball bearing.
gm280
If the bearings themselves don't have any numbers on them, you can always measure the bearings and see if you can line up some with the same specifications. I've done that before myself. Just an Idea. And usually measure in metric will get you the correct ones easier as well. A cheap micrometer will do the trick. JMHO
