kfa4303
Banned
- Sep 17, 2010
- 6,094
Hi all. So I was inspecting the trailer and noticed that my hubs/bearings have grease zerks rather than the typical nut and cotter pin set up that I'm more familiar with. How do I service/replace the bearings, or do I just pump them full of grease using the existing zerks? It looks like they had spring-loaded bearing buddies caps, which have long since been lost. Can I/should I remove the zerk set up and convert to a normal bearing buddy set up? There also appears to be a disc/seal that has come free from the backside of each hub as well. Thanks for any help. Also, does anyone know a good place to look for trailer tires? I need 3 x 4.80-8 long range (Class C?) tires and an extra 4-hole rim to use as a spare. Thanks.
