Bearing buddy O-rings - is there a size chart anywhere?
Homerr
Mine aren't necessarily 'bad', but the trailer has been sitting so I'd like to toss in new O-rings on my bearing buddies while I have the hubs apart. Anyone know if there's a size chart for the Bearing Buddy O-rings?
Mine appear to be measuring 59.5mm - 60mm OD x 54.5 - 55mm ID with a cross section of 2.5mm. It's always tough to measure used O-rings accurately - especially these thin ones.
McMaaster's web site shows a standard O-ring of 60 x 55 x 2.5, so I'm going to assume that's the size I need, but an official size chart would be extremely helpful!
With any luck my local hardware store has them.
JimS123
Whats you taking bout Willis?
I have used BBs for many years and none of them had O-rings"
dingbat
dingbat
These things are so cheap, why would you want to rebuild one?
It’s been a while, but the last time I checked SS BBs where $85 a pair and I need 2 pairs.
If I can fix all them for $2.00 in o-rings and an hour of my time, I making $169 a hour to work on my own stuff…lol
Homerr
I don't have to rebuild mine per-sey, - my boat has been sitting for several years and I wanted to put in fresh O-rings while I was doing my bearings. Not to mention my Bearing Buddies are over 20 years old. I think they deserve a fresh seal! Mine are the 2441ss model.
Good news though.. I contacted Bearing Buddy and asked what size the O-rings were. They didn't answer that question, but instead are sending me new ones free of charge! THAT'S customer service!
I think the rings are 53 or 54mm OD x 2.5mm CS. It's difficult to get an accurate measurement with used O-rings especially with thin ones like these. I wanted to put in some better Viton types. Maybe I can get a more accurate measurment when I get the new ones for future information. I could always take the shotgun approach and buy a couple different sizes. They are less than a $1 each. Pennies for the regular Buna-type..
Thanks for the replies!
dingbat
Diameters are easy. A calibrated eyeball is close enough to distinguish one size from the other.
The ID are spaced roughly 0.060” intervals in the smaller sizes. Well with the limitations of caliper measurements.
I never rarely measure the o-ring proper. Always the measure the diameter of the groove on a shaft or the bore on a housing.
Wouldn’t waste my time with fluorocarbon (Viton) in this applications. Buna-N will hold up just as well chemically and you don’t have to deal with fluorocarbons nasty habit of taking a compression set.
