Bayliner trophy 2002 WA repair questions
Aaidan
Good day everyone,
I have a Bayliner trophy, 2002WA (cuddly cabin, 22', 175 Mercury Optimax outboard, trailered, not moored/docked, roughly 20 day fishing trips per year etc). Please keep the following in mind while reading my post: I have moderate to severe back pain caused by service related injuries (Afghanistan). I bought the boat, my first boat, for 15 000$. Ive been thinking of selling it and just buying something else (a little bigger, etc... Like a Striper 2901WA). What has been holding me back is my uncertain future, given my injuries and eventual medical release from the forces. I'm not poor, but I'm not rich, and my future is up in the air. Consider if you believe the cost of what I describe below will be too great in terms of material, time/ability when compared with the boat. I don't think having someone else do the work is an option due to the significant hourly cost.
When I bought the boat in 2011, the inspector told me I only had about 5 years until I had to re-do the transom (which he derived from the humidity test he did with a gun). How do I now verify this without having to pay him another 500$ for an inspection? Cracks have begun to occur in the plastic capping over top of the edges (on the edge that the main outboard sits, it is called off with plastic; this plastics hard clearly broke in the past and been caulked over, but new large cracks / fissures are starting to form which worry me as they are surely in contact with water from waves when they hit me from behind) Is there a way I can tell if it's still "safe"?'
I was also told that their were "bubbles" forming on the underside, that would need to be drilled, dried, and filled.
Also, I have several problems I need to work on, first, I have chips about dime to quarter size on some of my flooring, I'm wondering if it isn't time to re-do the flooring? Is it feasible to spray something like rhino liner and be done with it?
The u-bolt used to winch the boat to the trailer is... Not ripping out, but definitely needs some work (if only to re-seal around where is has pulled/worked a bit. Same thing for another U bolt on the transom that supports the weight of the kicker when trailering.
The carpet on the trailer skids need to be re-done.
I believe the anti-fouling may need to be re-done, how do I tell?
The "sealing agent" (black tar / putty type agent) used to keep the windshield in place (I imagine) has begun flaking off increasingly. Windows still seem to be sufficiently secure, but it worries me... Concern?
The carpetting just under the window, on top of the "console" for lack of better terms, has "burnt" with son exposure and is dryer and falling apart. I now have big burn holes in the carpet. I need to replace this, are their different options for material, or should I use carpet again? Do I have to remove the windshield to do a good job? Ref windshield point, 2 birds with 1 stone?
I want to replace my stock seating with something comfy to sit in all day, for someone with back problems, suggestions?
I would like to make my bimini bigger in front and back to give me more sun protection. Actually, I would love to buy or build a hardtop to replace it all together.
I want to install more rod holders. Can I simply drill them in, wherever (within reason)?
I would like to increase my storage options for rods, etc, within the cuddy (install rod holders on roof of cuddy, so I can not sleep and keep gear secure). Same Q as above, can I simply drill wherever?
I would like to turn one of the integrate fish boxes into an insulated cooler... Feasible? The other I would like to turn into a real fish box/live well for the catch... But this probably means installing a pump, insulation, a seal? Maybe replacing the lift off panels with ones that flip up with a compressed air cylinder to hold them up and a proper seal around the edges...?
I would like a "project boat," and this could be it. I could buy another, and restore this one slowly... But I do not own any indoor storage big enough... And it's worth mentioning that I have very bad allergic reactions to some glue... So I would have to be very careful (I developed it while making button snowboards in my youth, so I have some exp with fibreglass... But I can barely remember those days). Given this, I have been thinking it may be worth trying to restor an aluminum bass type boat to component my current / future dual purpose cruiser/fishing boat.
Any opinion / advice welcome. Thanks for taking the time, I apologize in advance for all the typos there must be... I'm posting this from my phone in bed while trying to find sleep.
Thanks again.
redneck joe
Welcome to the forum. Lots o lots o questions in one post but I'll sum up my response. All your things can be accomplished time and money if that is the boat you want. The transom will most likely put you out for a season or you could pay to have it done over the winter prob a couple grand and that is where I'd start.
Bayliner made a nice hardtop model.
Keep in mind if you sell yours without fixing the transom you will need to inform buyers of that. Then any new to you boat may have the same issues.
tpenfield
My opinion, others may vary . . .
Unless you really love the boat and want to keep it for a long time, I would set my sights on the bigger boat.
You will want to check the transom of your current boat. if you can somehow access the inside of the transom and drill a few small test holes to see if/where you have moisture/rot. Otherwise you could just do some percussion testing with a rubber hammer on the outside of the transom to see if you are getting 'hollow' of 'solid' soundings.
If you have to fix the transom, it would be a bit of a project. All the other stuff, I would let a new owner deal with, rather than putting time, $$$, effort into it.
If you want to keep the boat, then you could go through all of those things that you mentioned . . . maybe get some help from friends for the things that you may need help with, etc.
First, than you for your service
Second, Welcome aboard
check out the transom by drilling as mentioned above. if you have access to some of the stringers check those too.
if the transom is wet and your starting to see cracks, its most likely in need of repair. so would the stringers.
the floor will need to be replaced to get to the stringers, however yes, you can rhino line your boat. works great for fishing.
the blisters on the bottom of the boat may or may not be an issue
the bow eye could be simply loose, could be the wood backing bar fiberglassed into the boat has been compromised.
spray foam insullation works great to turn a livewell into a cooler
top of the forum are stickies. 3rd one down is the DIY stuff. if you need to get into the stringers, etc, read link #14. links 2, 3, 4a, and 4b are some detailed how-tos on working with fiberglass
in the general guideline forum, there is a topic on uploading photos (think its a sticky)
Aaidan
Joe, thank you for the advice, I will definitely consider your POV. In the end, it is not the boat I want, it was always a stepping stone; it being the first boat I truly own.
Tpen, Thanks for the info on the transom, I will look into how to do the drilling. I'll start out with the rubber mallet, that I can easily do sometime tomorrow.
Scott, thanks a lot for the detailed answer. Will definitely check out the posts you recommend.
Does anyone have an idea (I know it would be a very rough estimate) on how much it could cost to get the transom done?
Thanks!
redneck joe
I'm in TN and the design of my boat didn't require the cap to be pulled and it and the motor mounts were 2500, plus 650 for pulling the motor which is an i/o
Aaidan
2500 is maybe doable. I kinda found a way to do a free inspection (or the transom) today, but gettin an estimate done. I told them the price of the estimate would obviously determine what I do, but this may be a great way to get it checked and see if it's at least safe (though I know they will try to sell the repair).
A big bonus is a friend from kindergarten works there as a salesman. He was talking to me about the possibility of selling, for like 10, and then buying a younger, less used striper for 40, which may come meet most of my goals. It's definitely something to consider.
mickyryan
if the transom is toast you could just strip boat part it all out and then trash it or do like they do on craigs list , list it as a project boat and have somone interested come haul it off , "one mans trash is another's treasure" I don't see you getting 10 grand for a boat with bad transom especially a bay liner, I have always liked there hard tops though /shrug
