(Bayliner) Mercruiser Trim Gauge Problem
euroset
Dear Mr !
I have Bayliner Ciera 2355 (1996) with Mercruiser engine.
I have a big problem...
The TRIM gauge is not working.
I replace the trim gauge to new, and replace the TRIM LIMIT SWITCH and TRIM POSITION SENDER to new (factory, original),
but the gauge is not work !
I found some WIRING diagrams on the Internet, but i can't find the reason.
Question: The TRIM gauge, and TRIM position sender contact with each other directly, or
have an electronic control circuit someplace in the boat ? If yes, then where are the control circuit panel ?
I drew a plain electronic circuit, please see attachment (trim.jpg):
http://kepfeltoltes.hu/110106/1074635261trim_www.kepfeltoltes.hu_.jpg
This is right wiring, or
http://kepfeltoltes.hu/110106/trim2_www.kepfeltoltes.hu_.jpg
this ?
I measured it the (position sender) wires, and i found, one of the (BLACK) wire ist connect to negative ground.
But i can't find, where does join the another (black) wire (position sender).
Please help me, if possible.
Thank you:
Christian - Budapest, Hungary
Re: (Bayliner) Mercruiser Trim Gauge Problem
Ayuh,... Welcome Aboard,....
The 1st picture is about the way it should be,...
The gauge is powered by the igntion circuit,...
The sender Wire goes from the gauge, to the Sender, then to ground inside the harness...
It's not really passing Voltage, but it's meassuring Resistence to Ground...
euroset
thank you for reply.
Ok, but my trim sender ist 0-170 ohm resistance, but not fitting to my new (not factory) gauge.
Can i set up my gauge calibration to my sender ?
The gauge and the sender must match. There is no calibration for the gauge. Same is true for temperature senders, oil pressure senders, and fuel gauges.
