Bayliner leaking :(
Bt Doctur
The sift cable `s black plastic sleeve comes off first. loosen the 2 square head screws and pull off. loosen the locknut on the shaft and unscrew the guide with the brass barrel. some mercruiser cables have the brass barrel pined" at 6 inches
A good gimbal bearinf fell like spinning your finger in a jar of Vaseline
ilove2fixx
Gimbal is good that sound was my arm hitting the metal shift rod thingy lol what an idiot i am
And the BIG problem now is i managed to strip the brass nut to a round nut : (
I trie everything so im going to take it to my friends mehanic shop and hopefully they can get it out im prayin.. damn shift bellow causin all this headache annd money
ilove2fixx
I see how your arm hits that but the bearing still doesn't sound good.
No the bearing makes no sound , it was my arm hitting that other piece lol i tried it again today and lifted my arm .. no sound smooth bearing
ilove2fixx
But my big issue now is getting that round brass shift cable nut off, extraction tool ? Or those special gripping sharp sockets ?
Bt Doctur
If you mean this nut, usually 1 in 10 had water in there and it breaks and needs to be drilled out and retapped with the correct tap.Not a hard job.
ilove2fixx
Yup that one.. man my luck.lol i just wanted to change a $10 bellow now its gonna turn into a $200+ job lol that nut is in there.. i tried everything but extraction and tap .. no bueno real bummer
Bt Doctur
1/4 x 18 NPST this is a straight tap, NOT A PIPE TAP correct drill size is 29/64
