Bayliner Exhaust Manifold Replacement
Tony the Greek
Just purchased a Bayliner Capri, 2050 with a 4.3L Mercruiser, 175 HP. The only thing wrong with it is that it needs a new exhaust manifold, i'ma pretty good mechanic and I have good help too. Just need to see if anyone has done one of these on this boat or a similar to see what it entails. Also can you just replace one manifold?? Will it effect performance? Please help if you can!
Thanks!
Tony
gcboat
Re: Bayliner Exhaust Manifold Replacement
If it's a freshwater boat replacing one side shouldn't be an issue. Guess it all depends what's wrong with it.
Make certain that you purchase the correct gasket set. It will take a couple of adjustments to get the torque correct ( hot, cold, hot, cold etc. ) but it is pretty critical to be on the money.
The job is not that hard. If you say you're good with a wrench then it should be a walk in the park.
If in doubt - buy a manual. :D
