Bayliner 2005 problem
kathrynalb
We have a Bayliner 2005 at a weekend lake cabin and every weekend when we come back it won't turn over at all until we hook the battery up to a charger - then it always starts. We put in a new battery and the same thing happened. We disconnected the radio and that didn't help. Any ideas? This started last summer. We only use the boat on weekends about 6 months a year and not every weekend. Even at that it only is out a couple times each weekend. Thanks!
JB
Re: Bayliner 2005 problem
Disconnect the battery when you leave, Kate. Something is draining it while you are gone.
A electrician can probably track down the charge thief.
Silvertip
Honorary Supreme Mariner
If the boat has a radio, the station memory and clock functions draw power constantly. Not much mind you, but enough that it will drain the battery. Install a master switch that shuts everything off (except the bilge pump if you have an automatic style).
nuttyboater
I was just going to asking about the bilge pump but i see i got beat to it...
If its sitting in the water while your gone, and not to say its leaking but it could be, rain could be another factor, then the bilge pump might be cycling on and off if its an automatic pump and causing a bit of battery drain.
Any power source nearby so you can just put one of those little battery maintainers on it? You could also get a solar panel to put on it if its sitting in a location you don't have to worry about theft, those things are dissapearing all the time around these parts, a friend of mine lost two of them on his pontoon boat.
Otherwise as suggested go with a battery cutoff switch but wire the bilge pump to the battery side of the switch so that it always has power. If your still coming back to a dead battery than start watching it closely and see if your having a water problem that keeps the bilge pump busy!!
