Bayliber Capri.. repower?
Neura
So i got a bayliner capri over the weekend from a buddy. Was thinking of restoring it or hotrodding it.
Working in fabrication i have access to mills and lathes and can fibreglass gelcoat etc. So i am not worried about the skill required or the time. This is just a project to keep me busy.
This is a 1990 Bayliner Capri with the dreaded force 120 L-Drive.
I am looking for another engine to replace the 120 Force as they are not reliable and hard to get parts for. I can make a new u-joint to match the splines to the L-Drive. Thats not a problem. I can also make engine adapters for mounting purposes.
So that leaves me with which engine would be reliable for this and preferabbly no 2 strokes. I hate mix :)
I may fabricate something to replace the L-Drive to use the orignal hole and mount a stern drive under neath, looks like it could be done just needs the correct housing and adapters built.
How would this affect boat weights for the water though. If required i could also fibreglass in the original hole in the bottom and mount a stern drive out the back and basically build a new transom.
Or order a swim platform and make a plate or fibreglass the hole in the bottom. And mount an outboard on the back of it.
I know the lower leg from these is actually a merc. Its the adapters (steering yolk, u-joint housing and u-joint) that is the issues on them. Also with any choice of new outboard to mount in original hole i relaize the engine will need to be internally balanced.
