batterys?
smallboatlover
Banned
when i boat my 14' boat it came with two batterys and im planning on rewiring it and i was wonder if i should wire it up to only one battery and keep more weight out and use just one battery. the 50hp motor charges the battery. the only electronics and power things i got on the boat is the running lights and a fishfinder, vhf. thats it and the motors a eletric start. i was thinking if i was to do that i should buy a little soler pannel to use when im anchored so i run a radio im thinking of puting in.
NYBo
Re: batterys?
Many owners of smaller boats go with just one battery. You may wish to carry a jump pack as insurance, though.
Forget the solar panel. The cheap ones are too small to supply enough juice to make a difference for what you're contemplating. Just get the largest battery you can fit, and take good care of it.
Silvertip
Honorary Supreme Mariner
Re: batterys?
On your boat one battery will suffice since you don't have a trolling motor. Forget solar panels as you would need one the size of your boat to actually "charge" a battery. The little ones are merely maintainers and help keep a battery that is already charged, from self discharging. Just make sure the one battery you do have is known to be good and keep the electrolyte level where it should be. Verify the charging is working. Your fish finder should show battery voltage of 13.5 - 14.5 volts with the engine running at anything above 2000 RPM.
smallboatlover
Banned
Re: batterys?
ok thats i was getting mixed replys but people i know saying that you should always have a second battery and other people saying its just extra weight. so ill be puting only one battery back in the boat come spring
5150abf
Re: batterys?
If you add a trolling motor it is a good idea to have 2 batteries but one will work, just be sure you have a pull rope on board just in case you do run it dead.
I have had to pull my 50 a couple times(before I had the 3 batteries) not fun but glad I could do it.
I actually have 3 batts on my 16'er, 2 for the boat and a starter so ti is almost impossible for me to run out of power.
shrew
Re: batterys?
IMHO, the battery bank should be sized based on usage, not boat size. If you have a small boat, and plan to do a lot of anchoring and listening to the radio, then you would probably be better off with 2 batteries. If you're fishing and doing a lot of drift fishing or fishing on anchor and want to run a depth finder for a long periods of time, again, you may want to consider a second battery.
Sure the alternator will charge the battery when running. What happens if you drain the battery as a result of running electronics or a radio while the boat is off? If there is a chance that the only battery you have can be drained to a point that you cannot retsart the motor at the end of the day, then 2 batteries and a battery switch is probably in order.
If you're not going to run 12VDC devices while the motor is not running, then one battery may be fine. Again, it depends on what you are using to draw 12VDC, how long you'll be drawing 12vdc, how much you'll be consumming over that time period, and what you'll be using to replenish the charge.
There is too little information here to properly answer this question.
keninaz
Re: batterys?
If you don't mind the extra weight you could also set the second battery up like an RV with an isolator that keeps it separate to the starting battery. I ran all my auxiliary stuff VHF, fish finder, stereo and bait tank water pump on the aux battery.
That way if I was sitting for some time and I ran that aux battery down I still had an isolated starting battery to start my motor.
It would have been really hard to pull start my I/O V8 in the Cuddy.:rolleyes:
smallboatlover
Banned
Re: batterys?
well i could do that but i was thinking of buying one of thoughs jumps start things that you can hook up to the battery and start it.
Silvertip
Re: batterys?
If you really want to run just one battery, make it the largest capacity you have room for and your budget allows. You don't have a trolling motor and no high current draw accessories. Depending on how long and how fast you run the engine it should stay charged. Even if you add a radio, it will not run down the battery unless you go nuts and add a high power amp. Use power responsibly, carry a jump start pack and learn how to rope start your engine. One battery will work fine. If you add a trolling motor then you are in a two-battery situation.
