I just purchased a 2005 Bayliner 185 and the voltage gauge does not work. The previous owner said it worked at one time. Is there something I can check? Or is the gauge probably just bad? Thanks!
Turn the ignition key to the run position, with your VOM check the voltage on the purple and black wires on the gauge. If you show battery voltage, you have a bad voltmeter.
