SavannahKen
Thread starter- Joined
- Jul 18, 2010
- 7
My 1998 Johnson 90 battery was totally dead after two week's storage. It wouldn't even charge. All switches for the LW and BP were off as were all other items. I had left the drain plug in and there was 6-8 inches of water that had accumulated during that time (rain) and completely covering the float and pump.. I went and bought a new battery thinking that the bilge pump had run and finally killed the battery. I started up the motor and ran it for about 5 minutes but did not take the boat out to sea. I thought all was fine. Well, went to start the motor the next day and the new battery was DEAD! Again, nothing was left on and it had not rained at night and I DID leave the drain plug out this time. My question is: Can a bad voltage regulator slowly drain a battery when the motor is not running? I have noticed that the DC voltmeter on the console reads max when running (16-18 VDC) OR Could 5 minutes of running a motor with higher voltage than normal kill a new crank battery?? Is the VR located where it can be easily replaced? One other item to note is that I bought this boat three weeks ago. It ran great the first two times out. The horn was not working and I quickly found that the positive lead was not connected so I re-connected it. The horn still did not work but I neglected to disconnect the positive lead. Could it be possible that a faulty horn switch/ horn could have drained the batteries? I did disconnect the pos. lead after the second battery was drained down. I appreciate any and all feedback.
