battery swtich help please.
smallboatlover
Banned
i Just boat the battery switch for my boat. it has four settings. 1, both, 2, off. How do i wire that up please help me. Does any one have a diagram or advise for it. i have two batteries on the boat.
NYBo
Re: battery swtich help please.
What, no instructions came with the switch?
Here's a simple diagram, courtesy of Silvertip:
smallboatlover
Banned
no no instructions. and what do i hook all my electronics too just one of those batteries? and when i shut the switch off it will make it so no powers going to the electronics?
Silvertip
Honorary Supreme Mariner
Stop and think about this. If you wired all the accessories to one battery, why would you need the switch? Everything, including the engine gets connected to the COM terminal on the switch. If you have an automatic bilge pump that is the ONLY thing that would need constant power. Next question is do you understand how to actually use the switch? If not, this has been explained over and over and over again in this forum so just use the SEARCH feature and key words "dual battery switch operation". Just think of the switch as a water control valve that determines where the water goes to and comes from.
smallboatlover
Banned
ok so i kinda get it. i wire it up like the one in the picture. And then wire the electronics to the switch? i Looked in the search thing and i couldn't fined any thing that explained it well enough for me to understand how to install this. so if i do whats in the diagram above, were from that point do i wire the electronics to?
smallboatlover
Banned
so i think i get it now. i wire it up like in the diagram. then i have a negative cable going to the bus bar. then a positive from the bus bar going to the com. The negatives of the battery's get hook together. then the positive from the motor go to the com with the other wire from the bus bar that has all the electronics. then the negative from the motor go to the battery. I i have a bus bar will all the electronics on that then run a positive from that to the com. them run a negative from the bus bar to the battery.
Silvertip
I have no idea how your boat is currently wired. You don't need all these bus bars. Just look at the diagram. Two batteries with negatives tied together. The negative cable from the engine gets connected to the negative post on either battery. Postiive of BAT #1 goes to #1 on the switch. Nothing else goes there. Positive of BAT #2 goes to #2 on the switch. Nothing else goes there. Everything you have connected to the POSITIVE bus gets connected to the COM terminal on the switch. Done. Go boating. Set the switch to OFF and nothing works. Set the switch to BAT 1 and you start the engine with BAT 1, bat 1 gets charged, and bat 1 powers everything. Same thing happens when you set the switch to BAT 2 but it powers everything, it gets charged, and it starts the engine. Set it to BOTH and guess what happens. Yup - both batteries power everything, both batteries start the engine, and both batteries get charged.
smallboatlover
Banned
Then what does the negitavie of the bus get hooked too? i under stand every thing else.
Silvertip
I would assume your negative bus is currently connected to the negative terminal of the battery or it would not be called a negative bus. So in that case, what is there to move? It is already connected to the negative terminal of the battery is it not??
