im new on these forums and this is my first post.
ive also done a good bit of reading on here and i have got a load of good information but im still not sure of how to solve my issue. i dont appear to have enough battery to power my boat and accessories. it has gotten progressively worse, but lately im not trolling more than 20-30 minutes before i get low battery beeps from my fishfinder.
i have an 03 sun tracker bass buggy with a 75hp mercury. there are 2 batteries, 1 interstate cranking battery and 1 deep cycle that i got from bass pro shops. the cranking battery is connected to the motor and has nothing else on it. the house battery has everything else on it, and by everything else i mean a 55# trolling motor, a garmin gps/fish/depth finder, stereo (i hardly ever use it), lights and the usual console stuff. i have already replaced the deep cycle once last fall when it didnt appear to be holding a charge. i charge them with an onboard 2-bank charger.
i have had this boat since last spring and when i got it i had the cranking battery and that was it. i added the trolling motor and a color depthfinder and the new battery and initially i would go out and get 4 or so hours of trolling without any problems. it seems each time i go out i will get less and less time and at this point it takes about 20 minutes to drain the battery down to 20%.
i thought there was a drain somewhere and took it in to get tested and im being told that nothing is draining the batteries and they are now at a full charge and appear to be fine. i feel certain that as soon as i get back out it will be the same issue of running out of juice after a half hour of trolling.
last time out i had to hook my console up to the cranking battery to use my depthfinder since the other battery was drained and i never put it back before taking it in and the tech at tracker is telling me to leave it that way. and have only the trolling motor on the deep cycle, and everything else on the cranking battery. i always thought the cranking battery was for the engine ONLY, and everything else should be on a house battery. he is saying i can also try putting in a third battery in a series to get more power to the trolling motor. it seems to me if i were to put in a third i should have one deep cycle for the trolling motor, one for the house accessories and one cranking for the engine, rather that having 2 connected together. is this right? he also mentioned that my cranking battery was dry. but the deep cycle had plenty of water. im looking for proper setup ideas and id rather not have a switch if i can help it. any ideas on why my house battery doesnt hold a charge?
