phercinger
Thread starter- Joined
- Apr 11, 2011
- 4
I need help guys. I had some ideas before but once I talked to u I became lost. I then used the search feature?.and still nothing. I will start here. First my boat is a 17 ? ft 1989 sea nymph, 70 johnson outboard . I have had it for 2 years. 3 weeks ago I tore the whole boat apart. I am rewiring the boat b/c no gauges worked, things were shorting out, and I do not know what was original to the boat. The guy before me really did a horrible job with wiring. Huge spaghetti mess. He also had 3 batteries. So that is where I stand.
My intentions: I want a fishing boat that I can just fish with the troller for a couple hours. (70 lbs thrust Minkota maxxum). I also want to be able to take my boat out to a big lake and feel comfortable with shutting motor off?sitting and enjoying some radio for a couple hours with friends?.then start back up without having to worry about battery dead .
Things I am gunna put into boat:
1. Gauges ?( 5) speed, tach, battery volts, fuel, digital depth
2. Key Starting/choke ignition
3. Nav/anchor lights
4. Radio with 4 speakers
5. Bow FISH FINDER front next to trolling motor
6. WATERPROOF fuse box
7. 8 led deck lights
8. Horn
9. Bilge pump
10. Live well fill
Rocker Switches on dash:
1. (On/off/on) Nav- gauge illumination /off/anchor
2. (On/off) LED deck lights
3. (On/off) Live well
4. (On/off) Bilge
5. (On/off) Front fish finder
6. (pressure button) Horn
So on to my questions:
I have looked at many ways to hook up batteries and don?t really know what?s best for my situation. I definitely will go with a battery selector switch. Off/1/2/both. Do I need a charging relay or is it a waste of money? I assume I don?t need a one because my 70 Johnson alternator will take all day running full out to charge the batteries anyway. Someone please explain this to me.
The guy before me had 3 batteries. One starter, two deep cycles. He ran the deep cycles to the 70 maxxum troller 24v. Do I need three batteries? Or will that troller be ok with one deep cycle? And if I stayed with one?..how would that work?......being 12v and I need it to run on 24.
I also have a charger that came with the boat?..three battery bass pro shops that I plug into my garage to charge. I would love to reuse this. If I use this?.does that affect if I need that charging relay?
Ok so first I would love the answers to these questions?..then I can move on to more technical wiring questions granted I come to a conclusion on the batteries. Thanks for your input?..looking forward to ur comments.
8. Horn
9. Bilge pump
10. Live well fill
4. (On/off) Bilge
