battery problem
coastalrichard
Re: battery problem
Please be mindful J...this is a "battery" fluids thread:confused::facepalm:. Go ahead...start another thread something like "break-in warranty requirements"...I got your back:D
Jlawsen
Master Chief Petty Officer
Re: battery problem
Yeah, sorry bout that, I alread used the battery check thing on Valentines day, the Optimas were a little dicey but no problem on the big ole Group 29 Interstates.
Davem3
Re: battery problem
so, they need checking EVERY MONTH, reuse as necessary ...............
it says so on the the sears web site for die hard batteries ................
MH Hawker
Re: battery problem
Well I have had to take a few days off due to rain so I have to go back to making sure the batterys are charged again. And I know the cooler is low again and I am real sure I heard the framus valve chattering. Its gona be a long summer. :D :cool:
coastalrichard
Re: battery problem
James, I'm beginning to think that your "low liquids sensing sender" may be malfunctioning. This is NOT GOOD. You should ohm it out to make sure it's at 100% before you go out again...and don't forget Deb:p
Davem3
Re: battery problem
i need one of those ohmeters , but there is NO way the little lady will join me .............
coastalrichard
Re: battery problem
Well Davem3, if you're not gonna take the Admiral with you when running fluid level diagnostics on the water, then I STRONGLY suggest you have an anchor and up-to-date flares.:eek:
MH Hawker
Re: battery problem
We spent the day out and dang cooler seams to stay low and was forced to just ride the boat around for several hours to charge up the battery, But the grill is working fine. :D
Davem3
Re: battery problem
huh, we must have bought our coolers, errrrrrrrr batteries at the same place. Mine had a terrible time staying full today, it took all day to "CHARGE" it back up, man that was brutal ..............
Davem3
Re: battery problem
all of the above, now checked and done, we do have to stay in Compliance ya' know ???
sam60
Re: battery problem
This is why I love iboats, great maint. ideas. I best take a Monday off and start with checking the fluids early Saturday morning. You can't be too careful with maint. Thanks for the idea.
coastalrichard
Re: battery problem
Well, dad gummit...noaa was WRONG...15 to 20"s never subsided on Saturday so I was relegated to conduct my diagnostics IN THE DRIVEWAY.:(
