Cady8special
- Aug 24, 2011
- 64
Just picked up a boat. The battery doesn’t charge- same voltage running or not, around 12.7v. Also there is no spark in the second cylinder. It’s a 2002 Mercury 4 stroke, 3 cyl. I swapped coil packs and the same middle cylinder has no spark. New plugs. I believe this to be a stator issue, but would like some input before I order the part. We checked voltage at stator harness- 3 readings were about 40v and one was about 16. Any other tests I could do?
Thank you
Thank you
