battery ground wire
sneakfox
i've got a 91 mercruiser, inboard,outboard. i bought a new battery for it replaced starter (car starter thats same size and shape, ) but when i try to kick it over, negative battery terminal , gets hot, and begins to smoke, does anyone have answer too cause, and also is it a bad idea to use car parts on boats ever if there the exact fit.
Re: battery ground wire
Ayuh,... Starters Absolutely Must be Marine rated,... It's an Explosion Hazard...
The cable is getting Hot because of Resistense,...
Remove,+ Clean Both ends, or Replace the cable...
HT32BSX115
Yes.
"BAD", illegal (FED law), and dangerous.
It sounds like a poor/corroded/bad connection and/or a defective starter.
You need to get the right starter for your boat.
Regards,
Rick
mkast
Ask yourself, "Why is there a difference between automotive and marine parts?" When fuel leaks on an automobile, where does the fuel usually drip to? When fuel leaks in a marine application, where does the fuel drip to?
Be the first on your block to become a statistic.
