mark156531
- Sep 6, 2014
- 14
I have a 1980 Johnson 85hp. With the engine off and the key removed from the ignition I performed some tests using a hand held voltage meter. I have found that there is .5 volts draining from the positive battery terminal to the wire going to the starter solenoid. I also found that there is .1 volts draining through the wire going to the charging system. Any thoughts on what might cause this to occur or what I should check?
Thanks
Thanks
