Re: Battery Charging
Charge it with 2 Amp setting if you have time, 10 Amp if in a hurry. You can charge the batteries trough an accessory plug like cigarette lighter or trolling motor plug. Assuming that you have selecting switch for your batteries.
I charge mine with the selector switch on "All" trough a cigarette lighter with "regular? setting on the charger.
If you are concerned you could charge with the ?deep cycle? setting with the selector switch on the #2 or deep cycle battery.
When done, switch to #1 or starting battery and switch the charger to "regular" mode to get to the starting battery.
