Battery charging. Should I disconnect?
sidefx
I have a dual Charles waterproof charger connected to 2 trolling motor batteries. I won't be using the batteries for trolling motor since I don't fish much. One of the batteries I have connected to a 150 watt sub woofer for the radio and the other is disconnected since it is dead and won't hold a charge. My question is, do I need to disconnect the sub woofer before plugging the A/C cable for the Charles charger in the wall? Will charging the battery cause damage to the speaker if I don't disconnect the speaker from the battery?
Re: Battery charging. Should I disconnect?
First, why lug a dead battery around. Get rid of it. Next, please explain how this speaker works that you have connected to a battery. They are normally connected to an amp or the speaker box has a built-in amp.
sidefx
Yes it is a 150 watt powered sub.. Has it's own amp..
I thought that's what you meant and NO, you do not have to disconnect it to charge the battery. Every vehicle on the road charges the battery without disconnecting things and you need not do that on a boat either. If the battery is in an enclosed compartment, open the hatch so any gassing can escape.
sidefx
Makes sense..Duh!! Thanks for the reply
