Has anyone had this happen before?<br />I haven't used the charger in a couple years and it never did this before.<br /><br />I'm pretty sure this is a common sense type problem and answer.<br /><br />The cause would be that the clamps are only crimped on and corrosion may have set in. (even though it doesnt look like it)<br /><br />The solution would be to cut the wires back a couple inches as needed, then clean everything and solder on.<br /><br />Any thoughts?
