Battery charged by motor?
jwb
Stupid question, perhaps, but I am not sure of the answer...Here it is...does the battery charge as you're running the motor (engine)? Have a 35 HP Evinrude.
petryshyn
Re: Battery charged by motor?
If the engine has an electric start, chances are good it also has a charging system. Yes, it should charge the battery while running.(only while running) :)
jwb
Thanks... It does have an electric start. It's a 1978 35 horse Evinrude so I'm a litle suspect to it actually charging. Is there a way to verify that the recharging is working. Right now I'm running with a new battery.
petryshyn
What electrical tools do you have at your disposal?
Walter
JWB...<br /><br />Using a volt meter, check the battery voltage with your engine turned off. It should read somewhere around 12 - 12.5 volts. Then start your engine (be sure it's in water or has ear muffs and garden hose attached) and then read the battery voltage. If your engine is charging properly...it should read around 13.8 - 14.2 volts.<br /><br />Walt
12Footer
Not sure of your engine, but some older ones didn't come with a charging circuit. Believe it or not, they were optional
clanton
Engine has charging system thats makes about 5 amps.
jwb
Walter,Petryshyn and 12Footer....Thanks for the information. I will do the voltage test.<br />Jim (jwb)
BBogey
You think that's stupid? I am TOTALLY a motor moron!!! I just bought a new boat/motor. The motor is a 60HP 4-stroke merc and I too was wondering if it had a charging system, then I figured it must!!! Now, I assume it charges my "cranking" battery, is there a way to "jump this charge" over to my trolling battery???<br /><br />Thanks,<br /><br />Signed, "embarrassed!" :eek:
petryshyn
The best way to charge both batteries is to install an isolator. If this is too inconvenient, just hook them in parallel (+to+ -to-) but use a toggle switch in line with a circuit breaker to separate them when the engine is not running. You could also use a common relay to do the switching for you (interfaced to the ignition switch.) Its not a good idea to hook them together and leave them together when the engine is not running. :)
BBogey
Thanks! Is an isolater a fairly easy thing to install? Is it something I could only get at a marine place, or would an auto parts store have it? (told you I didn't know squat!) :eek: <br /><br />THANKS!
petryshyn
Unless you have a good understanding of the electrical system, I wouldn't advise you to install an isolator. Best go with the second option with a switch and circuit breaker. . .Be careful when working with the electrical system. A wrong connection or a slip of a wrench can result in fires or even loss of life. :eek:
