Battery charge time
marka662
New to this, just wondering how long a dedicated optima blue top would hold a charge while powering a polk 880 and 2 polk 12s, and polk 660 pulling 4 kicker tower speakers. Anybody have any idea? Need to know so I won't have to get towed back to the ramp.
Silvertip
Honorary Supreme Mariner
Re: Battery charge time
You need to add up the max current draw your head unit and amps. That information can be obtained from the label on the equipment or from the specification section of the manuals. If the maximum current draw is 20 amps (20 AHr) then you divide that number into the AHr rating of the battery. The result is how long the battery will power the system. Whether it will start the engine or not is another question. We have no idea what you have. But with a high power music system you should have a second battery to power that system. Or better yet, a second battery AND a dual battery switch AND an on board charger to keep things charged up when you are at the dock. There is no concrete answer to your question since nobody can tell at what point the engine won't start.
