Battery booster question
79project
I have a 1978 1400 I just bought, sn 5092xxx. The batteries are shot, when testing the boat, the seller used a portable booster. I bought one of these to start with figuring i d charge or replace batteries in near future. Using new booster I get nothing but dashboard lights, no cranks, no starter click, dead silence. The booster states 12 v 500 peak amps, 182 A at 5 seconds jump starting. My debate is that the booster is just too weak for the motor or I have to start from scratch on the figuring out ignition problem. I just don t want to start a wild goose chase if it s just a battery problem.
Thanks
Texasmark
Re: Battery booster question
Yes. That engine will ruin 200 amps starting. My 3 cyl 90 of later vintage is spec'd in the manual at 150 nominal. Boosters that non professional folks buy (are available for us to purchase normally) are just not up to that kind of current for any length of time. Also a shot/bad battery is sucking on the power source also so you are just shooting yourself in the foot.
HTH,
Mark
Alumarine
I have a small booster like yours that works very well as long as it's just a drained battery.
I've boosted v8's with no problem.
Like Mark says though, a bad battery or starter might be too much for a small booster.
Texasmark
I had the Schumacher 50 amp booster for starting. I know it's not 200, but it was for smaller engines and yea verily you got your 50 amps, but don't blink cause when you open your eyes your 50 amps was gone.
HTH,
Mark
Coloradolakeboy
Don't forget to clean your battery connections and make sure they are tight, don't use wing nuts! An O.K. battery sometimes won't start the motor with dirty/loose connections
Alumarine
I guess mines a bit bigger, 450a with 900 peak amps although it's not very big.
It cranked a V4 Johnson for 45 minutes (off and on) while we tried to get all the water out of it.
That included running the power tilt up and down about 20 times as well.
79project
I'm still waiting on my new manual, feel like a kid waiting on the mailman. If i want to replace the battery, what size would be good for the 1400?
And thanks for all of the help!!
