I just bought a thompson 288 last fall,had it winterized. Then this spring,i reconnected the batteries to put in the water.They fired up without a problem.After sitting a couple weeks in the slip,they engines just click.I dont have a clue about the charger other than it hums and has a couple switches that can go on 1,2 or both. Also the cabin lights wouldn't work even when plugged into the shorepower. the boat manual doesn't explain jack about the charging system or the panel switches.The boat has 4 batteries.
