So I added a second battery. I have one regular marine flooded acid battery for starting and the second battery I added is a marine AGM.
I want to use the AGM for listening to music and stuff while the engine is off at the sand bar or whatever.
But say after using the AGM for a while I want to charge it. Can I start the boat on the reg battery then switch to the AGM with the engine running? I know I could start off the AGM and charge it but what if I use it enough where I cant start off of it?
I looked up my batt switch and it has make before break but does not have AFD.
Much thanks in advance
