BULL3TPR00F
- Mar 19, 2021
- 6
Hey guys and gals,
So I'm in the process of restoring/rebuilding a BassTender 11.3 Plastic (Polyethylene) Jon Boat.
I believe its the same material as all the other plastic jon boats out there (Bass Hound, Bass Raider, Pond Prowler, etc), which is polyethylene plastic (HDPE I believe).
I am replacing some of the fittings and pumps that go through the hull at the transom of the boat.
My main question is does anyone have any experience on what is the best sealant to use to seal up all the through-hull fittings? Everything I have been reading online says that its almost impossible for anything to properly adhere/stick to polyethylene plastic. I was going to use 3M 5200, but I also read that it doesn't stick very well to polyethylene as well. Most extreme plastic bonders I see online that claim to work on polyethylene are super glue type stuff designed to join plastic parts together but not really provide a seal.
If anyone has experience dealing with this material and has successfully done reseals and repairs on the material, any help and insight is greatly appreciated.
Thanks in advance.
Thanks in advance.
